楼主: zhaobingtao
报告大牛们,旋风器流场计算不收敛,如图所示,请指示
发表于 2004-6-2 12:54:09 | 显示全部楼层
文章无法作为附件!再帖一次,实在不行的话只有自己查找了
不行!
The influence of temperature and inlet velocity on cyclone pressure drop: a CFD study
Jolius Gimbun, , T. G. Chuah, A. Fakhru’l-Razi and Thomas S. Y. Choong
Department of Chemical and Environmental Engineering, Faculty of Engineering, Universiti Putra Malaysia 43400 UPM Serdang, Selangor D. E., Malaysia
Received 16 February 2004;  Revised 22 March 2004;  accepted 22 March 2004.  Available online 18 May 2004.
Abstract
This work presents a computational fluid dynamics (CFD) calculation to predict and to evaluate the effects of temperature and inlet velocity on the pressure drop of gas cyclones. The numerical solutions were carried out using spreadsheet and commercial CFD code Fluent 6.1. This paper also reviews four empirical models for the prediction of cyclone pressure drop, namely [Air pollution control: a design approach, in: C. David Cooper, F.C. Alley (Eds.), Cyclones, second ed., Woveland Press Inc., Illinois, 1939, p. 127–139] [Chem. Eng. (1983) 99] [Doctoral Thesis, Havarad University, USA, 1988], and [Chem. Eng. Progress (1993) 51]. All the predictions proved to be satisfactory when compared with the presented experimental data. The CFD simulations predict excellently the cyclone pressure drop under different temperature and inlet velocity with a maximum deviation of 3% from the experimental data. Specifically, results obtained from the computer modelling exercise have demonstrated that CFD is a best method of modelling the cyclones operating pressure drop.
Author Keywords: Cyclone; CFD; Pressure drop; Temperature; Inlet velocity
 楼主| 发表于 2004-6-2 17:54:03 | 显示全部楼层
非常感谢个位大牛的指点。
麻烦大牛把文章压缩成rar包就可以上传了。或者请指明文章的出处,刊物名称、年卷期页,谢谢!
发表于 2004-6-2 19:23:06 | 显示全部楼层
这么新,估计期刊网上还没有,最好能传上来。
做旋风的人还不少,看到很高兴!
发表于 2004-6-2 19:27:42 | 显示全部楼层
赵兄,最近有什么进展?
发表于 2004-6-2 19:28:45 | 显示全部楼层
做旋风的人还不少,看到很高兴!
发表于 2004-6-3 10:22:43 | 显示全部楼层
麻烦joy上传一下这篇文章,,3x
 楼主| 发表于 2004-6-3 20:53:16 | 显示全部楼层
钱兄:
最近忙着修改论文,没有计算。前些时候熟悉了一下fluent,算了一个传统结构的旋风器,我的课题是蜗向进口的,因有较小的尖锐角,用Hex/Wedge划分不成功,只能用四面体网格,现在还没有算。你最近呢?分级效率算出来没有?你的Injection设的是Group还是Surface?
发表于 2004-6-3 22:38:44 | 显示全部楼层
分级效率已经算出来了,和Leith&Izoia经验公式比较接近。还需实验数据来验证!
问题是这些经验公式都是针对单进口旋风分离器的,不知双进口可不可以套用?
我的Injection 设的是Group,每个Group里有10个颗粒。
发表于 2004-6-8 15:41:35 | 显示全部楼层
朋友门好,我把JOY提到的那篇文章传上来了.可在此文里并没有关于RSM模型收敛不收敛的讨论啊. 请问JOY所指的文章是我传的这篇吗?另外请教 fpingqian: 分级效率的计算用的是DPM 模型吗?如何定义粒子在不同边界上的边界条件的?积分步长是如何确定的? 我尝试了各种方法,对于粒子轨迹的模拟总是不对.希望得到指教.谢谢!
发表于 2004-6-8 15:43:27 | 显示全部楼层
MSN:xiangrb@hotmail.com
发表于 2004-6-8 21:19:06 | 显示全部楼层
除了RSM模型,谁用过LES计算过旋风器的流场吗?
发表于 2004-6-8 22:01:58 | 显示全部楼层
文献有人用LES,可是该模型对计算机配置要求较高,恐非并行不可。
 楼主| 发表于 2004-6-9 08:52:24 | 显示全部楼层
找专业的计算工作站去计算,呵呵
发表于 2004-6-10 15:55:45 | 显示全部楼层
我也在搞这个,一起讨论,讨论?
发表于 2004-6-10 16:00:15 | 显示全部楼层
另外,用LAgrangian怎么能得出收尘效率呢?简单的统计?另外,那个D50怎么得出来了。?
