返回列表 发新帖
楼主: godlikeme
[求助]盛满水的脸盆下面戳个洞,水以漩涡形式流出,怎样解释?
发表于 2010-5-26 00:44:44 | 显示全部楼层
麻省理工学院 Shapiro 教授1962年在 nature上的关于 bath-tub vortex的文章
Nature  1962.12.15 vol.196 (p.1080-1081)
Bath-Tub Vortex
PERENNIALLY one hears controversy regarding the direction of the vortex in the drain of the bath-tub or the kitchen sink. Some claim that the direction of swirl is always the same in the northern hemisphere and that in the southern hemisphere it is always opposite to that for the northern hemisphere. Other claim that there is no unique direction of swirl in either hemisphere.
Both schools of thought are in some sense correct. For the everyday observations of the kitchen sink and bath-tub variety. the direction of the vortex seems to vary in an unpredictable manner with the date, the time of day, and the particular household of experimenter. But under well-controlled condition of experimentation, the observer looking downwarl at a drain in the northern hemisphere will always see a counter-clockwise vortex, while one in the southern hemisphere will always see a clockwise vortex.
In a properly designed experiment, the vortex is produced by Coriolis forces. which are counter-clockwise in the northern hemisphere.
There are two reasons for the apparent haphazard results of the everday observations. The effective rim speed of a tank 2 ft. in diameter rotating with the earth at Boston, Massachusetts, is only about 0.04 in./min. This tiny Earth-induced motion may be much less than other motions too small to be perceived by ordinary observation. Unless the water in the vessel is allowed to settle for may hours, for example, the residual motions from the filling of the vessel may far exceed the foregoing figure. Moreover, the very act of pulling the plug from the bottom of the vessel may inadvertently create substantial velocities. Ever if many hours are allowed for settling, are currents in the room or thermal currents associated with nonuniform temperatures around the vessel may easily cause water velocities larger than that due to the Earth's rotation. All these difficulties are quite real;this was amply proved by early experiments with the apparatus desribed later.
The Second source of confusion in the casual everyday observations is that the Coriolis forces due to the Earth's rotation may in fact be much smaller than other forces normally prosent. For a speed of 0.1 in./sec toward the drain, the Coriolis force at latitude 42˚ north is about 3X10-7 times the force of gravity. If the vessel is not perfectly symmetrical about the axis of the drain, the asymmetrical viscous forces at the side walls and at the bottom of the vessel may produce torques larger than that due to the Coriolis force; the direction of the asymmetrical torque would, of course, vary from vessel to vessel. Even the extremely small forces of surface tension at the free surface may, owing to non-uniformities in temperature or chemical impurity, lead to torques.
A Meaningful experimental demonstration of 'the bath-tub vortex' must be designed to cope with the diffeculties mentioned here. Such an apparatus was made and operated near Boston for an educational motion picture entitled Verticity. The tank is circular, 6 ft. in diameter and 6 in. high, with a flat bottom. The drain hole, 3/8 in. in diameter, is centrally located and flush with the bottom. A length of hose some 20 ㄽ. long leads the water from the drain to a sump. A 'vorticity float' makes the vortex visible. This is a cross made of two slivers of wood, each about 1 in. long, pinned together with a fine wire through the centre of each. The cross floats in a horizontal plane just below the surface of the water, and a small length of wire extending above the surface of the water provides the necessary floating stability.
Before starting the experiment the end of the long hose is closed with a plug. The tank is then filled nearly to the brim with water swirling clockwise. This dirction is deliberately chosen to test whether sufficient time has elapsed for adequate decay of the original motion, so that one may be confident that the swirl seen in the experiment really arises from Coriolis forces rather than from initial swirl not yet sufficiently dissipated. After filling, the tank is covered with a plastic sheet to eliminate the effect of air currents, and the room is maintained at nearly uniform temperature. About 24 h are required for settling of the motion to a degree where the residual motions are unimportant compared with those dur to the Earth's rotation. The plug is then pulled from the end of the long hose and the vorticity float is delicately inserted above the drain hole. About 20 min are required for the tank to drain completely. During the first 12-15 min no rotation of the float is perceptible to the eye. At about 15 min, however, the counter-clockwise rotation of the vorticity float becomes distinctly perceptible, and gradually increases. Near the end of the experiment, when the vessel is almost completely drained, the vorticity cross turns one revolution in about three or four seconds. This is about 30,000 times greater than the effective speed of rotation of the Earth at latitude 42˚ N. It agrees in order of magnitude with what one would calculate theoretically on the assumption that the rotation of the float is indeed due to the Coriolis forces of the Earth.
When all the precautions described were taken, the vortex was invariably in the counter-clockwise direction.
If the plug were pulled after only about 1-2 h, the vorticity cross would begin to spin clockwise within 1-2 min after the plug was pulled, and would reach a rate much greater than the rate of counter-clockwise spin for the correct experiment. This was because the angular velocity remaining from the clockwise filling action, although not readily perceptible, was nevertheless greater than that of the Earth.
In one experiment the original clockwise swirl was allowed to settle for four dor five hours beforebefore pulling the plug. An unusual result was observed. During the first two-thirds of the draining period, the vorticity float turned in the clockwise direction owing to the angular momentum of the initial swirl. After having reached a large clockwise angular velocity, the float began to slow down, ultimately came to rest, and then proceeded to accelerate in the counter-clockwise direction. This may be explained as follows. The water acquires the rotational velocity of the Earth through the diffusion of a viscous shear layer, mainly from the bottom of the tank. This viscous boundary layer on the bottom, in which the water has acquired the counter-clockwise angular velocity of the Earth, grows thicker with time. Above this boundary layer the water still retains the clockwise angular velocity associated with the initial swirl. when the vorticity float sinks to the appropriate level, it tends to reverse direction.
I am prepared to provide precise particulars of my apparatus to anyone in the southern hemisphere who wishes to perform an identical experiment for the sake of convincing any remaining doubters.
Incidentally, those who claim to have seen the direction of swirl change as a ship crosses the equator are surely pressing the case too far. At the equator the Coriolis forces vanish, and it would be virtually impossible to perform a valid experiment a shot distance from the equastor
ASCHER H. SHAPIRO
Massachusetts Institute of Technology, Cambridge, Mass.
发表于 2010-5-26 00:47:39 | 显示全部楼层
其实,不管涡的方向是什么,它还是得符合角动量守恒。科氏力也只是在旋转坐标系中反映角动量守恒的方式。
发表于 2011-2-10 01:40:58 | 显示全部楼层
回复 27# ustcsunl 的帖子
关于这个问题最好的回答出现在动力论坛上,是coolboy在一个回帖中援引Pedlosky
的一个计算来说明,地球自转当然没有关系了(coolboy称其为见到的关于此问题最
好的回答)。看来Pedlosky也常为此类问题所不满,所以亲自计算并写了一短文章。
遗憾的是,我今天花了一个小时也没有找到这个帖子。
为啥气体动力学的书和船舶方面的教材中的方程都不包括地球自转的Coriolis 力呢?
显然是,根据尺度分析,可以看到对于本问题地球旋转是不重要的。
对于这个问题,其实问问研究飞机、轮船的同志:“你们做气动(水动)外形计算
时候要不要考虑地球自转啊?”
其实,这个地球自转不重要的说法,与夏皮罗的说法没什么矛盾。夏皮罗的实验让水歇了24小时,就是为了消除别的因素的影响。而很多实际情况,其他的因素可能超出了地球自传的影响,那么地球自转当然就不重要了。
这些结论不能当教条来记。具体问题,具体分析,用在这里很合适。
发表于 2011-4-25 20:15:45 | 显示全部楼层
原帖由 baroclinic 于 2010-3-26 12:03 发表
这种尺度的运动科里奥利力不重要。这里的涡旋运动是离心力和压力梯度力的平衡,所以既可以顺时针,也可以逆时针,与南北半球无关,更多地取决于初始的扰动。
终于有人不是 by-the-book 了...
科里奥利力的学说深入人心得让人不寒而栗啊...
发表于 2011-4-25 20:45:51 | 显示全部楼层
回复 34# flowinflow 的帖子
这种与“与南北半球无关”的说法难道不也是一种教条吗?
在不考虑实际情况的时候,一味的使用某个结论,很危险的。
还是要 具体问题,具体分析。这是马克思主义活的灵魂,也是我们做科学的活的灵魂。
