返回列表 发新帖
楼主: 地球全力
★★★银河警哨:“宇宙的第三大类涡旋”(奇异涡环),及未来航空航天理论
 楼主| 发表于 2021-12-28 22:34:42 | 显示全部楼层
5.7.“雪茄型太空母舰”在战损时的内部设备的拆分组合。
Fig.5.7. The separation and combination of airframe-exterior-equipment about the cigar-shaped spacecraft-carrier under Combat-Damage.
 楼主| 发表于 2021-12-28 22:36:30 | 显示全部楼层
5.8.“雪茄型太空母舰”和“碟形飞行器”的各种战斗状态。
Fig.5.8. The various combat-states about the cigar-shaped spacecraft-carrier and the saucer-shaped spacecraft.
 楼主| 发表于 2021-12-28 23:40:58 | 显示全部楼层
5.9.“雪茄型太空母舰”在大气层内释放和回收“碟形飞行器”的飞行状态,及母舰飞行时的“直接侧力控制”和“直接升力控制”的喷流系统
Fig.5.9. The cigar-shaped spacecraft-carrier are releasing and recovering the saucer-shaped spacecrafts in the atmosphere, and the Jet System of Direct Side Force Control and Direct Lift Force Control during flighting.
 楼主| 发表于 2021-12-28 23:42:03 | 显示全部楼层
5.10.“雪茄型太空母舰”在大气层内利用多发动机系统的反推力和机体头部正激波的阻力,表现的“飞行器的主被动制动状态”
Fig.5.10. The cigar-shaped spacecraft-carrier is behaving the Active and Passive Braking Status,which using the reverse-thrust of the multiple engine-systems and the resistance of normal-shock-wave of the airframe head in the atmosphere.
 楼主| 发表于 2021-12-28 23:43:01 | 显示全部楼层
5.11.“雪茄型太空母舰”在大气层内进行“直角转弯、锐角转弯、圆弧转弯”,及利用气动升力而表现的“空中竖直悬停状态”
Fig.5.11. The cigar-shaped spacecraft-carrier is showing off the Right Angle Turn, Acute Angle Turn, Arc Turn, and behaving the Vertical Hovering Status in the air.
 楼主| 发表于 2021-12-29 00:47:41 | 显示全部楼层
5.12.“雪茄型太空母舰”在恒星系之间加速到10%的光速航行时,用粒子束和激光束及旋转磁场,应付迎头而来的“星际尘埃”和“高能宇宙粒子”
Fig.5.12. The cigar-shaped spacecraft-carrier is accelerating to or flying under the 10% Light-speed,which is coping with the Interstellar Dusts and the High-energy Cosmic Particles,with the Particle Beam,the Laser Beam, and the Rotating Magnetic Field.
 楼主| 发表于 2021-12-29 00:48:25 | 显示全部楼层
5.13.“雪茄型太空母舰”到达太阳系的边缘的“奥尔特云地带”时,由提前派出的“碟形飞行器”,捕获一系列的“慧星和小行星”,在母舰的航道前方预先粉碎和电离成“纳米颗粒云”和“等离子体云”,让母舰在进入“内太阳系”前利用一系列方法减速到1%的光速
Fig.5.13. When the cigar-shaped spacecraft-carrier has been reaching the Oort Cloud Zone in the edge of the solar system, it has dispatched the saucer-shaped spacecraft in advance to capture a series of comets and asteroids, which has been crushed and ionized into the Nanoparticle Cloud and the Plasma Cloud, for the carrier will decelerate to 1% Light-speed with a series of methods before enter the Inner Solar System.
 楼主| 发表于 2021-12-29 00:49:25 | 显示全部楼层
5.14.“雪茄型太空母舰”在“内太阳系”以1%的光速航行到达太阳时,利用“太阳风和太阳大气层”进一步减速
Fig.5.14. When the cigar-shaped spacecraft-carrier has been reaching the Inner Solar System with 1% Light-speed, it will further slow speed to zero with the Solar Wind and the Solar Atmosphere.
