楼主 |
发表于 2003-7-28 23:10:16
FEM 入门
Files you may copy include:
flow6.f90, the source code;
flow6.tec, solution data suitable for input to the graphics program TECPLOT;
channel.out, output from a channel run.
elements.txt, element information suitable for input to the graphics program DISPLAY5.
uvp.txt, solution information suitable for input to the graphics program DISPLAY5.
The list of routines includes:
MAIN solves a 2D steady incompressible flow using finite elements.
BANDWIDTH computes the lower band width of the Jacobian matrix.
BOUNDARY_INTEGRAL sets data useful for boundary integrals.
BOUNDARY_INTEGRAL_FREESLIP sets boundary integral data for the freeslip.
BOUNDARY_INTEGRAL_STEP sets boundary integral data for the step.
BOUNDARY_INTEGRAL_PRINT prints data useful for boundary integrals.
BOUNDARY_SHAPE returns the tangent and normal vectors along the boundary.
BOUNDARY_SHAPE_CAVITY returns the boundary of the cavity problem.
BOUNDARY_SHAPE_CHANNEL returns the boundary of the channel problem.
BOUNDARY_SHAPE_FREESLIP returns the boundary of the freeslip problem.
BOUNDARY_SHAPE_STEP returns the boundary of the step problem.
BOUNDARY_VALUE evaluates boundary condition functions.
COEF_READ reads the coefficient data from a file.
COEF_WRITE writes the coefficient data to a file for possible restart.
DGB_CHECK checks the dimensions of a general band matrix.
DGB_FA factors a matrix stored in LINPACK general band storage.
DGB_PRINT prints nonzero entries of a banded matrix.
DGB_SL solves a system factored by DGB_FA.
DVEC_AMAX returns the maximum absolute value in a real vector.
ELEMENT_PRINT prints out the elements.
ELEMENT_WRITE writes element information to a file.
EQUATION_PRINT prints the equation types.
FP computes the jacobian matrix A of the Navier Stokes residual.
FP_PRINT prints information about the jacobian.
FP_DIF estimates the jacobian matrix by finite differences.
FX computes the residual RES of the Navier Stokes equations.
GEOMETRY sets up the geometry for any problem.
GEOMETRY_CAVITY sets up the geometry for the cavity problem.
GEOMETRY_CHANNEL sets up the geometry for the channel problem.
GEOMETRY_FREESLIP sets up the geometry for the freeslip problem.
GEOMETRY_STEP sets up the geometry for the step problem.
GET_UNIT returns a free FORTRAN unit number.
HELLO says hello, prints the program name, date and limits.
INIT zeroes out data used by the program.
NEWTON applies Newton iteration, seeking a solution of FX(G) = 0.
NODE_WRITE writes solution information to a file.
PRESS_INTERP interpolates pressure values at non-pressure nodes.
REF_BF_L3 evaluates a reference element linear basis function.
REF_BF_Q6 evaluates shape functions for a 6 node triangle.
REF_MAP_Q6 returns the interpolation map for data on a 6 node triangle.
REF_QUAD1 sets abscissas and wquad1s for 1D Gauss-Legendre quadrature.
REF_QUAD2 sets up the 2D reference triangle quadrature rule.
SETBAS evaluates the basis functions at each quadrature point.
STOKES solves the Stokes equations.
TECPLOT_WRITE writes out solution information for use with TECPLOT.
TRANS_Q6 calculates the biquadratic reference element transformation.
UVP_NORM_H1 returns the H1 norm of the solution.
UVP_NORM_L2 returns the L2 norms of velocity magnitude, and pressure.
UVP_NORM_LMAX returns the infinity norms of velocity magnitude, and pressure.
UVP_PRINT prints out the solution.
UVP_QUAD_VALUE evaluates U, V and P at a quadrature point in a given element.
UVP_VALUE evaluates U, V and P at any point in a given element.
X_OF_XSI computes X and Y given XSI and ETA coordinates.
XY_PRINT prints the X and Y coordinates of the nodes. |
