发表于 2004-8-23 12:59:20
POlyflow help file
judydan
The problem you met is the same as one I've met before. But that problem can be easily sloved.
1) don't follow the stupid HELP in POLYMAN, so called "standard system panel.." If you follow that instruction for Windows user is so difficult.
2) Now let me tell my method to solve the complaint. If you are using Windows XP, good easy for me to tell.
a) go to "My Computer" then you will see "view system information" underneath "System Tasks";
b)click it
c) the "System Properties" appears;
d) click "Advanced"
e) "Environment variables" can be found at the bottom
f) click it
g)At the 1st column, select "New" button
h) There are two blank columns asking for enter under title of "New user variable"
i)Enter " HOMEDIR" into "Variable name"
k) Enter a path into Variable Value" e.g. "c:\my documents\polyflow", in other words, you must produce a file named "polyflow" in your "my document by hand where all files stored there, must remember that! otherwise POLYMAN still will not obtain a path to search for the previous files
l) After running once POLYMAN, you will find that there is a initial file in "polyflow"
OK, all done, no more complaint! Nobody can beat your smart brain!
Carl Jiang ^_^
